Fitting window frosting with Vinyl lettering
Mata
Hi everyone
I'll be honest and say I don't fit that much window frosting and when I do, I just apply wet with some baby shampoo and water. However, I've got into a bit of an issue with an install.
I need to reverse cut some vinyl and apply it to the window facing out, I then need to flood coat it with frosting so children can't pick at the lettering.
I always fit frosting wet but when you are overlaying vinyl lettering, water gets trapped and you cannot push the water out. Any tips for this? I can't find any videos on this at all!
I finished the job doing the lettering part dry and then wetting the rest of the frosting and applying the dry but I always get some streaks in the adhesive in the dry parts. I'm sure these go over a couple of days but it's not nice to see.
While I am on this topic, when I use masking tape to hold the graphics in place, it never sticks that well, what are people using? This has always bugged me and I've always just got on with it but I'm getting frustrated as it takes me longer and then unsticks at times allowing the graphics to fall.
somcalmetim
They have air-release adhesive frosting now, install it over the lettering dry like normal.
We do everything dry and only use water for clear stoneguard.
Mata
I found the air release peels off a lot easier. Unfortunately where it gets fitted, kids have a habit of picking it with their fingers, we don’t have the same issue with standee frosting, so much harder to pick at it.
somcalmetim
Seems like you traded one issue for another, in that case you will just have to do a good job installing it dry.
Do a good middle or top hinge and get an extra pair of hands to hold it out so it doesnt touch the window before you squeegee.
Mata
I found the air release peels off a lot easier. Unfortunately where it gets fitted, kids have a habit of picking it with their fingers, we don’t have the same issue with standard frosting, so much harder to pick at it.
Mata
Thanks.
I was hoping there would be some way I didn’t know about but I agree, air release would have been the way to go.
