bigben
Hi, I have a 4ft high X 5ft wide sheet of 1/8 DiBond that I need to attach to an interior wall with a Z-Clip. Without using screws, how should I bond the Z-Clip to the DiBond? I was thinking to use two rows of z-clip for a better hold. Is it overkill? If you have another suggestion other than Z-Clip, I'm open minded. Also, if I want to ''stick'' the dibond directly on the wall, would it be safer (not sure of this one)? The wall is a simple painted drywall.
Thanks.
Ben
Thanks.
Ben
