flexi 12
kenrag
i have mutoh 1624x run by flexi 12 ... all of sudden my heaters have stopped working ,,, i think ita in flexi somewhere ...i do have the heaters enabled ....i think the rip and print and production manager are not working together ....some box is not checked to make the heaters work .....i cant find that box for nothing
Drip Dry
I don't know of any settings that would enable the heaters. Can you poll the machine and get a response, Then I think Flexi is working
Seems that maybe the heater is enabled in the Mutoh, but just stopped working
kenrag
Well when I looked at the machine the heaters were on .... unless some fuse or board has gone out
jcskikus
Owner, Designer & Installer
Just like you need to tell the machine when to DoubleStrike, it has to be enabled both in the software and the printer settings itself. If the fans are enabled both physically and in Flexi's settings, I'd start looking at a fuse or whether the fan finally quit. Plug another fan in, like a computer fan [making sure the voltage is the same or just use a voltmeter if knowledgeable] and see if that is the issue.
If you know for sure that the heaters should be on and hot and they aren't, it's usually a bad thermistor or a bad heater relay board. The thermistor is what reads the temperature so the heater knows when to turn on and off. The relay board is what actually routes the power.
