Flexi 22 - Show Me plotcommand to Summa 140T S3
2ny
Hi all.
We just replaced a Summacut S140T plotter with a new 140T S3 class.
The new machine was easy enough to install in Flexi, and it works straight out of the box.
However; the function in Plot/Cut command window in Flexi "Show Me" does not work on the new plotter.
At least not as it is supposed to do. When I click this button it does not show me the area the plotjob is going to fill (as it did with our old plotter), but the plotter shows me the current config in the plotter display for a few seconds.
I would much prefer it to show me the area it is going to use in the current plotjob, and hope someone else has been able to solve this here?
Best regards.
Tony
FrankW
I have no answer to this specific question, but I know that, while the S3-cutters are mostly compatible with older drivers, there are some minor differences. Could be that this is one point the new cutter won´t support with the older driver.
2ny
A little update; My supplier reports that this is an issue that SAi/Flexi has to fix. The commands that flexi sends to the plotter for the function "Show me" is somehow rationalized away by the plotter, since the commands do not contain any cut commands. Or something like that.
I hope they do something with it for real. The function "Show me" is very useful for controlling that you have loaded the media correctly and that your vinyl is long enough for you current job.
Tony
