Flexi 7 Question
hankweezie
I use Flexi 7 I want to know if I can combine a photo with text to cut out the text with the fill in of the picture, I seen it done years back but don't know if 7 is capable and how to do it.
:thankyou:
Fred Weiss
If your Flexi is the Pro version you should be able to do so. Just put the text on top, select both, and execute the Mask command.
CS-SignSupply
I believe this will work with Expert, Pro and Designer. make sure the vector text is layered on top of the bitmap. Select Both and click on EDIT>MASK>MASK
