Morph1
Print all
Hey guys,
I just spent some time contour cutting to sort of have a feel for it running it on the hybrid roland sp 300,
again my past background was mimaki with summa plotter for contour cutting which worked amazing...
I have a small problem understanding how Roland reads and associates the registration marks..., I noticed when I run a print with contour cut set in place,
roland prints the image printing also the 4 circles and that small bar as registration marks, now right after printing I ran the contour cut sequence and the printer finds all the
registration marks cuts the image perfectly, great , very happy with that ... now next step was to print the same image sheetcut it and laminate it... all went good
image is laminated , now I load that vinyl back in to the printer I run the contour cut sequence the head starts moving finding all the registration marks however it does not cut
exactly as the path indicates missing the image perimeter by a quoter inch over... , I don't quite understand it how it can miss the position of the cut path when it finds all the registration marks...
Example: in summa opus it does not matter where the material sits in the plotter or where the file is placed on the rip print area, over to x,y 0,0 or x 2" over it does not matter
once summa finds all the registration marks it cuts the image path perfectly.... what is happening with the roland ?
Do I have to load the vinyl in exactly the same spot in the printer and then have the artwork positioned in the exactly same spot in the rip window??
This is a bit strange as I thought once the registration is found the printer would determine the exact position of the graphics between the registration marks and contour cut the graphics
exactly as set up in the file, instead it finds the registration perfectly and cuts the graphics incorrectly...
any help would be appreciated
thanks.
thanks.
