Hi all,
Got questions regarding flexi flex cut and summa.
Been using the contour cut for a while but never really used the flexcut.
So this is my first try.
Setup the file in illustrator, created 2 spot colours, named CutContour and PerfCutContour.
Also separate the curves into 2 layers.
Flexi detected both curve and separate them into 2 layers, 5 Opos mark created on each side.
Drag knife on cutcontour layer and flexcut accurate on perfcutcontour layer
As usual, Cutter scanned the first 2 mark and the xy line, everything running perfectly, cutcontour run first (because the layer is on the top I assumed?) then the flexcut.
After that cutter moved to scan area, continue cutting but just the flexcut, it ignored the cutcontour and keep going with the rest of the mark until it finish without doing the cutcontour.
My questions:
-How to fix this issue?
-In Flexi summa cutter option, there is a menu tool 1 (0-6), what is this? I didn't see any change when I put in any number.
Thanks in advance.
My questions:
Thanks in advance.
