Need Help Flexi Crashes and Deletes the file
trafficbarriersolutions
TRAFFIC & BARRIER SOLUTIONS, LLC
Hi,
I recently started having this issue in Flexi. Whenever I try to save a file like this even smaller bits, it will crash and display this message: "Fail to Save D:\Folder\File.fs" click "OK", then displays: "An unknown failure has occurred. It is recommended that you restart the application." Cannot close it via top right so I have to go to Task Manager in Windows to force close Flexi. Then I try to go back and open the file, the file is gone. Why is this happening? Is this because my flash drive is getting almost full of storage?
visual800
check storage on flsh drive or start saving to external hard drive instead of flash drive I think it s flexi problem myself what version are you on?
chrisphilipps
How much space do you have left on your drives? Flexi needs to be able to write temp files to the drives, normally the C drive unless it was changed. If your C drive is full it can't write those temp files and it won't be able to save the actual file. If your D drive is full it won't be able to save the file either.
  • Agree
  • Informative
Reactions: 1 users
It is on Flexi 22.0.3. 14.3GB with 10.8MB left of free space of the flash drive.
chrisphilipps
10.8MB isn't a lot of space, especially if Flexi is creating temp files on that drive as it is trying to save. Try saving it to the C drive if you can and then see if you can copy it to the flash drive.
  • Agree
Reactions: 1 user
GamecockGrafx
Wow....14.3GB is a super small drive....10MB isn't even enough to temp save most "normal" applications. I get this problem a lot with Adobe and the dreaded "scratch disk full" error. When this pops up on me, it shows I have a terribly small HD (256GB, and like 7-10 GB free...) not gonna work with those numbers.
I'm not a Flexi expert, just a user, but my Adobe programs allow me to go in Preferences and set an additional temporary save area - so I just have a 1TB portable HD plugged in and will most likely never have a save problem again. Hope you get things worked out.
I will have to upgrade storage. I just have to be careful on editing large work files to not add or change anything until I get more storage.
