Flexi - Where are my Ink Limits? :)
OLE
I am using Flexi 8.5 and there is no button Ink Limits under Color Managament Tab. In the previous version(PhotoPrint 5 and earlier) ink limits could be changed for every channel(CMYK).
Do you have any solution for this issue?
Bannerday
If you go to job properties, there is a color adjustment icon (3 colored bars). In there is a graph that shows 100% ink usage. Just change the percent and the graph should change.
The default is all channels, but you can select each channel individually.
