Flexi7 Production Manager Not Loading
Just got a new pic HP with Windows 8. I have Flexi 7. I have had it running fine on a Toshiba laptop and Gateway all in one desktop. Loaded Flexi 7 and have everything setup same as other systems setup wise. I have installed Cut Master 2 1.94, I can text plot from the there but here is where the problems lies.
When i Send job from Flexi 7 to cut, the Production Manager never loads up (cut master loads fine) no error message or timeout comes up it just stops responding. and i have to Ctr alt delete to get out. Anyone experience this out there or think it has to do with windows 8? program works as it should no issues. I have uninstalled and re-installed flexi as well with no luck. as well as cut-master and driver.
Here is the kicker, if i use the cut-master in illustrator it works. (What i do know is different is the production manager que is different then the stock Flexi 7 que, that it loads on the other computers i had. ( I have also tried to load cut-master 2 1.83 (the one that came with the graphtec).
Thanks for reading hope i can figure this thing out.
