Flexible vs. standard white UV ink for outdoor tactile signs?
For UV-printed tactile signs and maps with braille and raised lines that are installed outdoors, has anyone compared flexible white ink with standard (rigid) white ink for the built-up layers? Standard white has worked well for us on acrylic so far, and I'd like to hear how the two have held up for you over time in cracking, lifting, and wear from touch, and what made you choose one over the other.
dtfonestop
For outdoor tactile work the tradeoff usually comes down to hardness versus movement. Standard white cures harder, so it holds sharp dome and line edges and stands up better to fingers and cleaning, but it's also more brittle. Outdoors the substrate expands and shrinks with sun and cold every day, and acrylic moves quite a bit, so a tall stack of rigid ink is where you tend to see hairline cracks across the build or lifting starting at the edges after a season or two. Flexible white rides that movement much better, but it's softer, so it can scuff, round off a little or feel slightly less crisp under a lot of hands.
What I've seen work well:
1. Keep the bulk of the build in whichever ink adheres best on that substrate, and put a final layer or two of clear or gloss on top. The top coat takes the wear from touch, and the layers underneath only have to stay stuck.
2. Don't stack taller than you need. Keeping the braille dots and raised characters at the required height instead of overbuilding takes a lot of stress off the edges, which is where lifting starts.
3. Prep matters more outdoors than indoors. A clean alcohol wipe at minimum, and an adhesion promoter on anything slick, since water getting under an edge is usually what turns a small lift into a peel.
4. Test both inks before committing. Print the same tactile sample in each, put them through some quick hot/cold cycles (freezer, then a hot window or a heat gun on low, a few rounds), then do a crosshatch tape test and a hard thumbnail rub on the dots. Leaving a couple of panels outside facing south for a few months tells you even more.
5. Think about the substrate too. Something that moves less with temperature than acrylic, like an aluminum composite or a phenolic-type sign blank, makes either ink last longer outdoors.
If your rigid white is already holding up well on acrylic indoors, a hybrid stack with a protective top layer is often the easiest way to get it to survive outside without giving up the crisp feel.
Forty One
Make signs they said... It'll be fun they said...
where are you located? your Building Code standards may come into play.
In Australia, our code states that the tactile & braille sign needs to be 'encapsulated'. We clearcoat ours so the durability is there.
I use LH100 inks from mimaki. hard and I havenot had issues with them.
I would say that if you didnt clearcoat, the ls inks probably would be a better solution, but they wont be durable compared to my previous comment
