Florida shop — 10 callbacks this year for laminate edge staining on IJ280. What are you running?
BOTS
Hey guys,
Shawn here. I run a wrap and graphics shop in Florida. I do mostly full vehicle wraps, but on partial wraps and logos I’m printing, laminating, and contour cutting.
This year alone I’ve had 10 callbacks for the same issue, and I need to get ahead of it.
Current construction:
3M IJ280
3M 8428G laminate
Print → laminate → contour cut
Within 6–12 months I’m seeing brown staining forming between the laminate and vinyl at the exposed cut edges. It follows the cut line exactly.
This is happening on:
• Printed and laminated contour graphics
• Unprinted laminated cut letters
So I don’t believe this is a solvent off-gassing issue.
Most of my work is full wraps and those have been fine. The problem seems specific to laminated contour-cut graphics on partial wraps.
Vehicles are parked outdoors in Florida sun. Some get washed, some probably don’t.
I’ve contacted 3M multiple times. The response I’m getting is essentially that moisture wicking can occur in humid climates and there isn’t much that can be done aside from edge sealing. The maintenance bulletin they sent does not specifically address wicking under laminate at contour-cut edges.
I previously ran IJ180 for years and don’t remember seeing this level of edge staining come back to me (though I wasn’t specifically watching for it).
At this point I need to protect my brand and reduce callbacks.
I’ve used Avery in the past and while installation is nice, removals at 5 years have taken me 3–5 days and left significant adhesive compared to 3M, which I can usually remove in a day.
So I’m looking for real-world feedback:
• If you’re in high-humidity climates (Florida, Gulf Coast, etc.), what print wrap film are you running?
• Are you edge sealing all laminated contour graphics?
• Have you seen this specifically with IJ280?
• Is IJ180 still the safer long-term fleet choice?
• Has anyone switched to Arlon SLX or another brand and seen better long-term edge behavior?
Not looking to bash any manufacturer — I just need honest installer experience before I change materials across the board.
Appreciate any input.
— Shawn
MrDav3C
Have to say I've never seen this before but we rarely use 3M and obviously the climate in Florida is significantly different to our own.
I have to wonder if it's a faulty roll or batch of laminate or if something is going wrong during the lamination process (i.e. too much tension causing the laminate to stretch during lamination perhaps).
The data sheet does state that too much ink coverage can cause the over laminate to lift so perhaps this still could be an outgassing issue and you are seeing this on the unprinted outlines edges where there is no ink so less resistance for the ink to outgas. - I personally doubt this as you have said it's happening on unprinted laminated cut letters also.
If this is a fairly new issue, you have been using the IJ280 for a long time and your setup hasn't changed then it has to be a problem with the print media or laminate, either 3M have changed something with the product or it's simply faulty would be my guess.
Things like this are extremely frustrating, no-one wants to hear their graphics have failed unexpectedly a few months down the line after an install.
Hopefully someone with more experience using the IJ280 or someone who has seen a similar issue can shed some more light on this!
BOTS
Appreciate the input.
I’m going through a roll every couple of days, so this isn’t tied to a single batch, and my setup hasn’t changed. I run an Epson solvent printer and typically let prints sit 4–24 hours depending on coverage. Since it’s also happening on unprinted laminated cut letters, I’m having a hard time blaming it on outgassing.
What stands out to me is how consistent the staining is — it follows the contour cut exactly. I’ve also started noticing a lighter version of it along trimmed door edges on full wraps, just not as obvious since it’s not outlining a decal.
I’m open to the idea I’m missing something, but at this point I’m trying to determine whether this is climate-related edge wicking and if I should be running a different film for contour-cut work in Florida.
GaSouthpaw
From experience, I can tell you that 3M does suffer from occasional ... quality... issues. They will absolutely not admit to them, barring months and months of submissions of batch numbers, product numbers, photographs, etc. We were a 3M contractor, and they sent us something on the order of 250 rolls of laminate with QC problems- haziness, contamination in the adhesive, defects causing a weird splotchiness- it seems once one problem went away, another one popped up. About three months later, we were sent a like number of print media rolls that had been contaminated to the point that any print with more than about 20% ink coverage was completely useless.
Again, this was their material, for their contract work, going to their customer, and it was like pulling teeth to get them to admit the fault was the media.
When it works, I feel like 3M is the best media around. When it doesn't... yikes.
Personally, I'd think your best bet would be to investigate alternate brands (Oracal and Arlon spring immediately to mind) and see if one of them works better for you, because your brand is important to you- not the manufacturer.
Best of luck to you.
  • Agree
Reactions: 1 user
BOTS
Thank you for that. I really appreciate you sharing that experience.
I’ll be honest, I’ve definitely seen more inconsistencies since around 2020. Nothing catastrophic, but enough to notice. The last 10 feet of almost every laminate roll has some haze to it — it usually clears up in the sun, but it’s there. I’ve also had a few wrap rolls with small defects that forced me to reprint sections. Nothing that stopped production, but not something I saw much of years ago either.
That said, when 3M works, it works. The removability after 4–5 years in Florida sun is hard to beat. I’m a one-man wrap shop and I remove about one wrap a month before rewrapping. I’m also installing 1–2 full wraps a week. If removal turns into a 3–5 day glue cleanup job, I’m in serious trouble time-wise. That’s one of the reasons I’ve stuck with 3M.
For those of you running Arlon or Oracal — how are they really for removal after 4–5 years in a Florida-type climate? And how do they behave in deep Transit and ProMaster channels long term? About 90% of my wraps are Transits and ProMasters, so channel hold matters just as much as removability.
Trying to make a smart move here, not just jump brands out of frustration.
DChorbowski
Pixel Pusher
Any remote possibility that these vehicles are all going thru the same car wash? Could be a chemical in their detergents reacting with the laminate adhesive. Have you tried any other overlaminates than 8428?
  • Informative
Reactions: 1 user
White Haus
Not a Newbie
Yikes, that's brutal. Can't say I've ever seen anything like that before.
We strictly use IJ180cv3 + 8418G and haven't had any issues with that combo, aside from the defects on the laminate on the last few yards like you mentioned.
I'm not familiar with the films you're using - are they supposed to have better durability than the previous versions?
I like Avery 1105 EZ RS + 1360Z for full wraps, but no bueno when it comes to anything shape cut. The combination of the low tack and EZ apply adhesive doesn't work well with smaller shape cut stuff.
BOTS
I doubt washing is the common factor. Some of these vehicles look like they’ve never been washed, and others belong to customers who are very particular and say they wash them a couple times a week.
BOTS
Good to know about Avery. IJ280 is one of 3M’s newer films. It stretches about 20% more than 180, is supposed to stay down in curves about twice as well, and installs about 20% faster. It also doesn’t leave glue lines like 180 can when you pick it up and lay it back down, which has been nice during installs. its a great film other then this issue I am having
White Haus
Not a Newbie
Eliminating the glue lines would be a nice bonus, that always drives me nuts with IJ180cv3.
To me it sounds like it's an issue with the laminate. It's not that the vinyl is failing, it's that the laminate is allowing moisture/dust in along the edges.
I know it's a downgrade (from 8yr to 6yr according to specs), but it might be worth giving 8418G a shot? An extra 2 years of rating doesn't mean much if it's failing within 1 year and 3M isn't standing behind it.
We've been really happy with it. It's the only gloss laminate we use and haven't had any failures whatsoever. We're not in Florida so climate is different, but we go from +35 to -35 Celcius over the span of 6 months.
  • Agree
Reactions: 1 user
BOTS
Very possible it’s just the laminate, which would honestly be an easy fix. The hard part is not knowing for sure until a year down the road.
signheremd
Why not keep the 3M vinyl and use a different PVC cast wrap laminate? Like Oraguard gloss 290 or Briteline WrapCast Optically clear laminate (which is apparently 3M, though I have seen none of these issues or imperfections as mentioned, and yes I know the Briteline WrapCast vinyl is supposedly Arlon)? If Covid taught me anything, it is that vinyl and laminate of different brands but with common characteristics can be interchanged (learned this due to necessity with supply chain issues). You won't get your warranty from 3M this way, but you are not getting it now with this failure anyway. Lastly, why are you laminating non-printed cut vinyl? Cast cut vinyl is 9-10 years anyway. Not sure what the point of edge sealing some of it in the photos was either. Maybe I am understanding it wrong, but you did say unprinted laminated cut letters.
  • Agree
Reactions: 1 user
BOTS
Come on… 3M has a warranty? That’s a good one
I laminated the non-printed cut vinyl because it was stacked in with the other prints and I had room on the sheet, so I just ran it all together instead of switching over to my usual Oracal 751. Glad I did, though — since 3M was initially leaning toward outgassing, this pretty much ruled that out.
I’m cautious about mixing brands on laminate. I’ve seen cases where the laminate shrinks faster than the film and exposes ink at the edges or even contributes to channel lift on Transits. I don’t want to trade one problem for another.
  • Agree
Reactions: 2 users
unclebun
Best way to deal with the job re-dos you showed will be to buy some 10 yd rolls of cut vinyl. Navy Blue, Cardinal Red, Spring or Emerald Green, Black, and Gray, and fix those vehicles with that. Guaranteed no laminate failure when you don't use laminate.
If you know the Avery wrap vinyl works for you, but you have to remove one wrap a month that takes longer, you might consider that a better deal than having to redo every vehicle a year later. We charge by the hour for removals anyway, so if it takes longer it pays more.
BOTS
I keep a full stock of cut vinyl letters and use that most of the time, so solid colors really aren’t the issue. The problem shows up on the edges of partial wraps and on printed letters with gradients. These days everyone wants fades and blends — it’s not like 10 years ago when a solid color was enough.
I could switch to Avery just for printed cut letters, and I’m not really worried about removal on letters since those come off quickly regardless of film. My concern with Avery is full wraps — removals are brutal compared to 3M, and that’s a big deal for me.
Ideally, I’d like to run one print film and one laminate, print the entire job together, laminate everything with the same material, and keep the workflow simple. I’m already working 12-hour days, seven days a week, so anything that speeds up production matters.
I’m really hoping to hear from someone in a similar climate who can share what they’re running long-term and whether they’ve seen this issue, thank you so much though!
unclebun
Did a little research into the overlaminate adhesives. 3M 8428G and 8418G and Avery DOL1360Z all use acrylic adhesive, But the 8428G specifies that it's "hot melt acrylic" where the others don't specify that. I wonder if it's actually different and might be the cause..
  • Agree
Reactions: 1 user
BOTS
That’s really interesting, and honestly that could be the issue. I just wish 3M would be more straightforward and say, “It’s the laminate — switch to 8518 and you’ll be fine,” instead of dancing around it.
  • Agree
Reactions: 1 user
BOTS
thanks everyone for the input.
I just got off the phone with Arlon. The rep I spoke with actually worked for 3M for about 8 years, and she mentioned they’ve seen similar edge issues come up before, including a large wrap shop that pursued it legally. That definitely got my attention.
At this point I’m going to run a test with Arlon SLX+ paired with their V3370 12-year laminate and see how it performs in our climate. If it holds up on contour cuts and partial wraps without the edge staining, that may end up being my new standard.
Appreciate everyone taking the time to weigh in. I’ll report back once I’ve got some real-world time on it
  • Agree
Reactions: 1 user
