Looking for a profile for an s80600 that can get as close as possible to a Fluor yellow. I know it won't get there all the way but I'm convinced it's nearly possible with the capabilities of this printer. Also what rgb value are you guys using for a Fluor yellow.
Profiles are very specific to printer / ink / media and their settings, you know? You never mentioned what media you’re using or a plethora of other settings. If someone were to send you a profile, how would you know if your machine behaves the same as the one from which the profile was created?
In any case, it was easy for me to lookup fluorescent yellow at the Pantone website. Using the sRGB color space the values are: 237, 255, 0, or edff00 in Hex, or 96, -23, 92 in Lab for PANTONE 13-0630 TN Safety Yellow.
Sure enough, holding a fluorescent yellow hi-lighter marker and a fluorescent shop-cloth against my monitor confirmed the match.
Despite what you may have read in earlier posts, the color seems to fit in sRGB and certainly Lab. After all, the Lab color space describes mathematically all perceivable colors and even the lowly sRGB color space standard for
computer monitors can emit as much yellow-green light as the fluorescent yellow you’re looking for. Although many ICC profiles reach the gamut, the prints from your machine will only come close (as you expect) because the ink and media simply does not have the characteristics of other true fluorescent processes such as dye sublimation printing or special ink with optical brightener additives.
You might check any profiles you have by using the gamut warning tool in Photoshop using the values from above. I find it’s within gamut of many profiles I have on my system for media I use.
Good luck.
