Behrmon
Pr. Bear-Mon
Hey all, question for those of you running industrial type humidification systems (Maybe you Gene?). What are you using for a commercial grade RO system to feed your fans? What have you found to be a good fit as far as GPD and Pressure needed to feed these systems? Will be feeding 2 Revolution 2s.
Also in regards to placement, where did you end up putting your fans in relation to your printer(s), these will be specially for an Arizona 2360.
TIA!
Kevin
TIA!
Kevin
