Need Help Fotoba XLD170 WP - *Scanner not reading
Shariff
We are having an issue with the cutter where the scanner isn't following the Vertical cut mark (Onxy Fotoba marks - Single Mark and even Double Vertical Mark)
Note it is reading and cutting the Horizontal marks perfectly; also note we are in the home decor segment so we print wallpaper on a Canon 1650.
Steps we do to scan the marks,
1. Scan Horizontal mark -} mark accepted
2. Scan Vertical mark Left green light turns on and beeps ( which indicates it has scanned the cut mark and accepted it )
3. Click Start -} begins to cut -} initially it cuts straight but then it starts to move and the alignment keeps moving
* Once the cutting begins the green light turns off.
* Print sizes tested on the cutter 52" x 30", 52" x 60", 52" x 120"
* Have tried offline and even when it is connected to the printer and feed directly into the cutter still same issue
PLEASE HELP !
tulsagraphics
PLEASE HELP !
How clean / crisp are your registration marks? I've had that problem before, and it was due to the reg mark bein' a little too fuzzy in places. Come to find out my print profile wasn't optimized. Recalibrating solved it. (hopefully it's an easy fix like that)
tulsagraphics
Oh, this was an old thread. Oops. lol
