Hey guys I did some print head maintenance on the Cyan unit to get some nozzles back in our Fuji Acuity Advance HSX2.  What I did was took the cover off the gantry, removed the hoses from the Cyan reservoir and drained all the ink out.  After that I blocked the return hose to the reservoir and attached a syringe full of flush/cleaning solution to the inlet hose of the print head and pushed the fluid through trying to clear up some of the nozzles I had missing.  This was a last ditch effort trying to keep the print head going, and it worked quite well. I got everything put back together then I did a Short Ink Flush of the Cyan unit to get all the air out of the lines.  Now to the problem, ever since I did all that it takes my Cyan's reservoir double the time of any other reservoir to fill.  This sometimes results in an INK FILL TIME OUT error.  While this isn't a big issue its bothersome.  If anyone has an suggestions on how to remedy this situation I would be grateful.
Thanks!!!
			Thanks!!!
