Garage Decal material
glow30
Hi All, Question client wants to put logo on a garage door. 72" x 40 " we print on Roland. Suggestions for material and do you recommend lamination?
It's a contour cut oval shape logo.
DL Signs
Never go against the family
You may get so many recommendations on different brands, your head will swim. Everyone has their favorites. You definitely want to laminate, unless it's a short term graphic. If the door has a factory finish, you should be ok, if it's been repainted do an adhesion test since a lot of paints designed for easy cleaning and repelling dirt also repel vinyl. In that case, you may need a vinyl with more aggressive adhesive, but any exterior/ automotive line will work.
Personally I'd go with an air release for easy application, automotive style, something along the lines of 3M IJ-40 polymeric if it's flat, or IJ180 cast if it has texture or profiles that requires something more conformable, top with whatever lam is recommended by the mfgr in the sheen the customer wants. Those are my go-to, but we're a mainly 3M shop.
What brand of vinyl is your go-to? Use what you're familiar with, and can get through your vendors, every brand has compatible lines with everyone else (if it's not 3M it'll probably be lower cost). An air release, either polymeric calendared (so it doesn't shrink), or cast, and appropriate lamination. Very straightforward. Print, lam, cut, clean the door & lay it, collect a check, & go get lunch.
Reactions: 4 users
signheremd
I agree with DL Signs. Will Add that I would use a cast product for this due to weather and sunlight exposure. In Avery I would use MPI 1005 EZ (EZ is air release, I would not use the RS as that is wrap vinyl and will require post form heating) or Oracal/Orajet 3951 RA (Rapid Air release, not the ProSlide wrap vinyl). If you do use a wwrap vinyl, pay particular notice to post form heating the edges.
Reactions: 1 users
Mike Paul
Super Active Member
Cast 3M 180 CV3 Media and 8518 cast laminate.
If you don’t stock cast film because of it’s price outsource the prints and do it right.
Reactions: 2 users
