Gbc titan 165: out of control, unresponsive
IceTrikes
Hello, this morning our titan 165 was working perfectly well, but when I turned the machine back on the second time today it began running at full speed, without any controls on the control panel working or affecting it at all. The motor will only stop running when I turn the machine off or the emergency stop button is pressed. Has anyone experienced this issue before on here? Thanks.
netsol
The is some sort of SCR or TRIAC that shorted, so it feed full supply voltage instead of regulating
IceTrikes
Make sure the run button isn't stuck. Is the speed control knob responsive?
There is no speed knob on ours. I tried lowering the speed while it was running to no effect. I wonder if it is some kind of crossed wire in the control panel
karst41
Is there a way we could check if this is our issue? Do you have any recommendations to fix this?
Here is my reality check point.
Does this piece of equipment make you money? Is it Essential?
I think ACCO services GBC. Your laminator is essential and to tear into it
is a bad Idea. These suckers have enough amperage in them to instantly plant yourass 6' under.
You are probably looking at something like $450 an hour and $150 Travel plus Parts.
Maybe $750 or less ? Maybe more?
Is cheaper than buying a new laminator. A new and decently configured laminator is going to be close to $14K
Its cheaper than your 100,000 mile Maintenance Schedule for your car or truck.
