SellersSign&Design
Well the Edge is being a pain again. I got my last issue corrected, I just had to reinstall the drivers. But now I have more problems. I turned it on the other day and the foil motor was running constantly. I unplugged it and let it sit and it was fine. Then it started doing a rapid beeping when I turned it on, but if I disconnected it from the computer and unplugged it it would be fine after that. Now today I tried to run a job through it and it printed one color then started the constant beeping and won't stop. The display is blank and it is a rapid beep, but the beep cuts in and out almost like the beeper is going bad (it may be, who knows). Does anyone have any ideas? I took the side panel off and I can't see any obvious loose connections.
