When running the Gerber Edge we are having trouble with the colors lining up or with the registration. Used 3M 4 mill calendered vinyl The machine is clean enough to eat off of but I did notice the punched holes in the vinyl looking a little distorted... I tried to see if something was dragging and could not locate any points of friction. (I drew about 8 lines across the vinyl with a Stabilo pencil and ran the decals... looking for the pencil marks to be smeared or for traces inside the machinw where it was dragging... no luck)
Attached is a 3 color decal we are having the issue with... as you can see the purple is not lining up with the black. this run is only about 3 and a half to 4 feet long.
Suggestions??? Have a ton of work piling up for this thing and I can run it as is.. Thanks!!
