I have a 404 router that I have owned for 20 years. We recently moved it to our new location. I don't know that that is relevant but maybe. My dad and I wired it up and at first I had a Z encoder error. I couldn't figure anything so we let it go for the night. The next day it was gone. I cut one job and thought all was good. Next time I went to cut something the Z encoder error was back and I can't get rid of it or figure out what is wrong.
The AMP FAULT light is red when you power the machine on. It won't attempt to orient. It goes straight to a Z encoder error.
EMGNCY SW FAULT light is not lit.
I've checked the up limit cable connections in the Z hood and at the electrical tower. All looks good.
I've swapped the Z and X cables with no change.
Z motor spins well with no obstructions
I removed the Z motor from the carriage and connected it right to the electrical tower with no change.
I swapped the Z and X servo boards with no change. I even bought another servo board that should be good with no change.
I OHM tested the Up Limit switch with my multimeter. At the plug in the Z tower I get .6 or .7 ohms. When I test at the tower end of the cable, the lowest I see is 1.3 and at the connector on the driver board I see 1.5. I tested the Y switch at the driver board just for comparison sake and that test ok. I swapped the X and Z up limit cables at the motor and the tower and I still get the Z Encoder error.
I bought a used Z motor/encoder and swapped that with no change.
I suspected the Z motor/encoder wasn't the problem because the machine doesn't even try to orient. I get the error as soon as I turn the machine on but I don't know what else to check or test. My guess is something on the motherboard but the cheapest one I can find is about $950. I'd pay that if I new it would fix the machine but I'm pretty hesitant to take the chance of spending that much money on such and old machine. Does anyone know how to further test these machines. Gerber no longer offer any support for them.
