Bare with me this might be a bit to read sorry.
I normally print on ultraflex jetflex 13oz matte banner material and it has been great for us.
Customer was in a pinch so I needed to last minute order a roll because I wasn't going to have enough to finish the job well fellers was out and only had gloss. Customer said gloss was ok so I ordered it up and loaded it in the machine.
Prints OK I am not a fan of gloss banner so I think the matte is way better print quality on it but here were the main issues that I struggled with:
-Banner material seemed a lot thinner on the gloss than the matte finish I checked all labels and they clarified that it indeed is 13oz gloss banner.
-I ran the same heat settings as the matte and it seemed to buckle the material a lot worse causing the head to strike in the middle of the roll. I lowered the heat settings and ended up with 40/40/50 degrees celcius on my heater settings.
Printed came in the next day cut them sewn them and rolling them up print side in the prints touched some how while rolling them up and you could hear a sticking noise like the inks were stuck together.
I then rolled it back and put it on the table to grommet and indeed where i hear the sticking noise of the inks "bonding" some of the black ink had been taken off.
I never have ran into an issue of ink not being dry after 14 hours of sitting heck let alone 30 minutes after the print I would always sew and grommet matte banners.
Should I change how long I wait to pull the banner off the machine for gloss finish? My heater setting is maxed on the post heater to try to initiate as much heat to dry the ink as possible before it gets rolled on the take up.
What are some banner procedures that some of you who print on gloss banner material use and suggest? I will be going back to matte and stocking PLENTY of it next time just curious so I am not wasting more 5'x20' banners.
Thanks in advance!
Thanks in advance!
