Glue/mount acrylic onto vinyl
willkho
Hi all,
I’m looking for some advice on the best glue to use for adhering 10 mm acrylic lettering to vinyl.
I’m aware that Weld-On acrylic adhesive won’t work on vinyl, so I’m hoping someone might be able to recommend a suitable alternative.
Thank you in advance for your help.
TEN
You can back the acrylic material with 3M 487 prior to cutting, then laser cut your letters and the 487 adhesive is cut to shape - ready to mount. For larger letters I would suggest foam tapes like - 3M VHB or Oracal has a less expensive version called Oratape UHB.
JBurton
Signtologist
I recommend this as well, mostly because it will spread the load across the largest area, because the vinyl will start to pull away from the surface it's applied to at some point, unless it's very thin acrylic.
I wouldn't mount anything too large like this without some studs...
