Hi! Just joined after finding your forum while looking for Vanguard info. I started working for a company here that has a VK300D that's been running since 2019 by people who don't understand the equipment. After my initial orientation from the manager - I began learning what I could and cleaning it up.
When I asked the manager questions he would say "I'm just telling you what i was told when i started...".
Getting access to the Vanguard service portal showed me factory bulletins and such which helped.
My first question was why was the bed covered with masking tape and paper outside the 4x8 part we were using? It leaks they said. Yes, it has selective vac zones but they didnt have the excess switched off! I shut down the excess zones and - no leaks (in those zones!) After cleaning the table of layers of tape and paper and ink, I found their problem was everything leaked! I had hoses with holes and/or collapsed underneath and several types of hose used. A little more research found a good chem/heat resistant hose with high vac capabilities and tight radius ability. Then I found out the clamps wouldnt tight enough to seal! A bit more looking and I replaced all the clamps with new design clamps that worked! No more continuous hissing and tape to hold the edges.! And on and on, other things came up (grease? we dont use grease... ?!!!) We do now!
And now -we have on the dock a VK3220T-HS! The only downside so far is they want to put it in the same room as the 300D and run both! But they are listening to my input and willing to make the changes needed. Their tech will be here soon and I plan on grilling him all I can!
Always glad to learn.. ive always been a believer in reading the instruction/books/manuals and doing it myself and usually you know as much as the techs do! Ive learned machine tool processes, Chevy/Harley and Land Rover mechanics, gunsmithing, electrical, etc and soon Vanguard!
