Grainy colors on Roland BN-20
betsy603
Hi all, I am having issues with some colors being grainy. It's not all colors. I know this printer can do it. I am wondering if it has to do with the media profiles? If it does, for the BN-20 there are basically no media profiles for ECO-MAX2 available on the website or thru the Versaworks DGA Connect. Or am I looking in the wrong place?
If it is the media profiles I need help locating them. For this particular picture I am using Roland GCVP. There is a profile for ECO-MAX but it won't work because I use ECO-MAX2. I am at a total loss and seriously need help. Thank you for any help in advance!
FrankW
Looks like problems with the bidirectional printing adjustment. Try to set your print mode to unidirectional.
AB Rolan
Print some block text and look at the edges of the block with a loop. You will see color droplets flying errantly make your beautiful creation look smashed into bits, or droplets..
I looked and there really aren't any profiles out there for this machine with MAX2 inks. For the profiles you do have, try one that as a (v) at the end of the profile name. That will print variable dot and should print smaller dots in these neutral type colors to reduce graininess.
