Graphix Calc Users, override size function and pricing vehicles
J
john1
Guest
Hey everyone! With the great help of Mike from insignia and Chris at GraphixCalc i have started fresh with the program and am finally dialing things in and getting the hang of it :rock-n-roll:
A few things that have me stumped is, When do you know when you need or should apply the "override size multiplier" and how do you go about pricing vehicle lettering for customers?
I know i have sign craft but like others have said, They don't know my material costs and I'm using graphixcalc so i don't have to use signcraft
A pair of doors would be easy since 12x24" would be a typical round about size but what would i do to get a pricing for a enclosed trailer for example or van?
Thanks guys!
J
john1
Guest
Anyone? Since making this thread i talked to Chris who makes Graphixcalc and i think that putting in the dimension for a trailer or box truck are way too expensive IMO. For a 7x14' 1 color basic it's telling me $1200 and signcraft is saying no more than $700 on the highest hourly rate.
Any help?
Fred Weiss
Two sides and the rear at 50% coverage, I would be somewhere between $1100 and $1250 depending on condition of the trailer and what rivets I had to deal with. I would be using cast high performance vinyl.
J
john1
Guest
Is that what you think coverage should be set to? I had it on 80% which was the default because i didn't know
Just trying to get the way to approach things like this down so i can start pricing against what my market is around here.
Fred Weiss
Answers to that will depend on the methodology of the person planning the work. Since my business has been largely keyed around 15" plotters since 1983, my production is always done in smaller sections and things like line spacing and shorter than 14' areas are not simply waste as they would be if cut on a wide format plotter. So I have found the 50% figure for actual coverage to be typical. Your default 80% figure sounds like it is either expecting to waste blank areas or be print in the first place.
Semi-related to this is my 60% rule for text layouts. The sum of the cap heights for a text layout is ideal at 60%. So if I am working on a 24" tall layout, the sum of the cap heights should be around 14.4". For example, a four line layout might be set to 6", 2.5", 2.5" and 3.4". The result will be neither crowded looking nor weak looking.
When I am pricing I am picturing what the finished job will look like and might adjust for heavier or lighter coverage. When I first start talking to the client, an early-on question is "Are you looking for major impact or basic identification with this job?" I am as much looking for things like a ton of small copy that will cost me more time than I am looking for actual material that will be consumed. Therefore, I have an average of three different pricing multiples that would be applied to the job depending on the coverage and the difficulty. Simple, normal, difficult. Light coverage, normal coverage, heavy coverage.
ChiknNutz
To keep this particular job in perspective, a 7x14 trailer/box truck consumes approx 250 SF of material (assuming 100% coverage for 2 sides and the rear for simplicity). At the low end of $700, that equates to just $2.80 PSF!!! Assuming that is installed (or not for that matter), that is laughable and totally unrealistic for a job of that size. Even if it is only 50% coverage, $5.60 PSF installed is simply too low for anyone to come out ahead. With the assumption of 50% coverage on 250 SF of installed graphics, that job should be in the neighborhood of $1000 (minimum in my opinion).
Fred Weiss
Chris, you're absolutely correct as you state it but you have based that on what is evidently some unknown information. I had to do the same thing. This is interesting as an example of how such a wide range of prices can result from the same example. It is a detail business and exact specs are important if one wants good feedback.
Because he stated 7' x 14' basic one color, my assumption is that the job would be done in cut and weeded vinyl. I calculated 98 sq. ft. for the two sides (50% coverage) and plugged in 16 sq. ft. for the rear for a total of 114 sq. ft. This translates to a range of $9.65 to 10.95 psf depending on the ease or difficulty of the trailer surface. The rest is just based on enough experience on this kind of a job to be able to quote based strictly on a square foot rate.
To me the basis for setting up an app like GraphiCalc is to have a pretty good idea what a job should sell for and then put that against what the app is saying. Another cross check would be to calculate time and materials which I would estimate at 12 hours to create the layout, proof and get client approval, produce the graphics and install.
12 x 75.00 (shop rate) = $900
Materials x 2 = $200
Total $1100.00
J
john1
Guest
Well i have some thinking to do, Local competition quoted someone $600 for this trailer (2 colors and sides only) i heard today. Including layout. Wow oh wow
Fred Weiss
With calendared vinyl and 30% coverage probably. I kinda comes back to the original question ... a rolling billboard or basic identification?
J
john1
Guest
How are you figuring out a rough coverage amount Fred? I know the trailer is 7x14' on the sides but it's cut vinyl so it wouldn't be 100% i know.
Just trying to get a few things priced on so i know what to do when i get a call for a ballpark as most get also. It stinks not having a clue
Fred Weiss
As I answered, you first need to determine what the client's expectation and purpose is. Ask them if they want advertising value or basic identification. Otherwise assume they want ad value.
In that case, you have 7 x 14 twice at about 50% coverage or 98 square feet for the two sides. You also have the back which has more exposure value than both the sides combined. Pencil that in at around 4' x 4' to 4' x 5'.
7' x 14' x 2 x .5 = 98 sf.
4' x 4' = 16 sf.
98 + 16 = 114
That amount of coverage will definitely grab the eye and get them noticed and remembered. I've quoted so many of them that by now I am pretty much in a range of $9 to $11 psf. for high performance cast vinyl and a pleasing layout. If they want additional design work, printed images or other labor, I would add that on. so what you presented was pretty straightforward with the only variations being
  • Reduced size
  • Excess copy
  • Rivets
  • Poor condition of trailer surface
Again, as I answered before, different people will look at the square footage differently. A wrapper is going to look at it as 100% coverage. Someone cutting vinyl but working with 48" stock, will be weeding away but counting the material that I would not be counting. But, in the final analysis, what we're really talking about is finding out what the client wants/needs and what we're actually basing our quote on. If your client is considering a $600 quote then he and you as well as you and I may be talking about apples vs. oranges. You must be very specific with quote information that supports your cause. Things like good design, eye grabbing sizes and quality materials need to be mentioned providing your client is looking for those kinds of benefits.
If he is looking at only doing two sides, he may not care about any of that. Then you need to predetermine that and offer your services in a way you can be comfortable and profitable in that price range. So, for example, you can calculate in reverse based on a square foot rate.
You might offer 30 sf per side in cast vinyl @ $10 a sf and be at $600. Or you might offer 43 sf per side in calendared vinyl @ $7 a sf and still be at $600.
