Question Graphtec 5100-150 Win7 & Cutting Master 2.200
thomas barth
Help!
I have searched thru the forums, but have not found this exact problem.
Graphtec 5100-150 Win7 & Cutting Master 2.200 cutting out of CorelDraw ... and the size of the cuts is just way off what the plugin out of Corel shows.
Its cutting almost 200% larger at times.
I am at a loss. .. any ideas guys???
Gary Wiant
So your using a cutter that is at least 3 generations old and a bridge software and you give users 1 day to answer your question and now the forum has lost its ability to help?
The only advise I can give you is dig through the bridge software manual and see what you can find. I had an issue a few years ago with an FC7000 & Signlab, it ended up being a setting in signlab I think it was called resolution or something like that. I would send a cut file of squares sized 1" 3" & 5" and measure them. I'll see if I can find anything when I get into the shop.
Good luck
