custom sign center
I have a Graphtec 7000-130 that I normally run using my Wasatch RIP program after printing. I've been wanting to do Perf cuts for pop out deacls so I need to use the Cutting Master 2 software to do that from since you need the decal contour cut and the perf cut offset from that.
I watched the instruction videos and printed a small file (3 decals) to test.
The cutter reads the registration marks fine but then won't cut the contour cut for the decals and I get a Error 1 Instruction not Recognized error. I tried switching the HP-GL command to GP-GL command but then it flys right past the reg marks alltogether so I changed it back. I've tried unplugging the USB and then replugging it in.
I tried just sending a regular vinyl cut file to the plotter but it won't go either.
I did notice one thing, after I open the Cut/Plot program the area (up in the upper left corner that shows the plotter) is greyed out. Also, I haven't updated the firmware yet to 2.0 (do I need to turn the plotter off to do this?)
I have called Graphtec twice and e-mailed them but have not recieved a reply yet.
I'm sure it's something simple I'm missing,
So...... if anyone has ideas I would really appreciate it.
FYI...I'm using Corel X3.
Thanks!
Thanks!
