Hi,
I've been using a Graphtec CE5000-60 for about 6 months now and I use both Robo Master Pro and the Cutting Maser 2 plugin for Corel Draw depending on the application. Most of the time, I need to cut my material at the slowest speed setting. As a result, the cutter will only move the slowest speed as it orients itself to the material width and between cuts. A few months ago, I was able to choose some setting that allowed the carriage to move at full speed while the cuts will be at the minimum speed. The issue is that I had to reset the factory defaults and now the machine has reverted back to moving at the slowest speed at all times. Does anyone know of how I can adjust the settings in order to make it move quickly again?
Thanks!
Thanks!
