matze214
Hey, iam using a Graphtec FC 9000 with a Holder/Knife Setup for thick Vinyl. Iam producing Motocross Graphic Kits. But since some weeks, even if i change the Blades the Cutting Lines are getting random. So the Cutter cuts some ways very good, then stops and getting really really sloppy to cut through.
My first thought would be the Teflon Strip. Could that be some Problem? Its a little bit worn off. Or which Problems or Signs should i watchout for.
Greetings
Greetings
