Graphtec FC7000-130
SignsRus
Plotter has been dragging the knife non stop lately.
I updated to the newest firmware (1.80) from the graphtec website, and cleared the nvram. Didn't seem to help the issue. I contacted tech support and they emailed me the newest firmware (1.90). I cleared the nvram again, and I'm still having the same issue.
The plotter will start cutting fine, then the knife won't pick up when it's finishing a cut, and it will drag across the material for the remainder of the job.
Turning the plotter off, and back on usually fixes the problem. It was only happening every once in a while, but these past 3 days it's been multiple times in the day.
Anyone out there experiencing anything similar? If so please help me out
Thanks in advance
- mark
bob
You might want to blow the dust and crud out of the tool carriage. Pay particular attention to the up/down mechanism. Most times a plotter that either doesn't finish a cut or cuts too far has a tool carriage that's binding because it's dirty.
SignsRus
Will give that a try right now. Thanks for the quick reply
SignsRus
We've also been having problems where during the middle of a cut it will say LOAD MEDIA. If we cover up the rear sensor with tape it takes care of that issue.
I'm really starting to think the machine needs to be sent in for service.
I have a Case# with graphtec already. Going to call here shortly and find out about a loaner plotter, and shipping.
Graphicdetailsinc
Running FC7000mk2-130 on wireless print server
I have spent the last 5 days ont he phone between graphtec, linksys, and scanvec amiable trying to get my fc7000 to work on my wireless print server.
I have finally got everything up and running, and if anyone would like to know what model print server to get what firmware to run and what setting to rip to in production manager i will be glad to walk you through the setup and save you the MASSIVE hassle i had to go through
Josh
Lunatic Taskbar
Graphicdetailinc, it may be worth writing down everything you had to go through as over time, things can be forgotten. (spoken from experiance)
But another thing that may be good is to add it here on signs101 as a tutorial, so if others search for it they will find it.
Anything that saves hassle is worth doing.
