Graphtec FC8600-160 Plotter Freezing all the time!
rcripe
I have a Graphtec plotter that I use everyday. At a minimum it freezes up 3-5 times a day. I have to shut it off and on again to get it to work. I'm using CorelDrawx7, Windows 7, and Cutting Master 2. Does anyone know why this is happening?
Dennis422
Why CM2 and not CM3?
Check your firmware version, update if there is a new one out.
Then re-set your cutter.
Make sure you take screen captions of your settings so you can reprogram later. (It will delete all your presets.)
First thing I would do is get Cutting Master 3 and update the USB driver if there is an update on the site. Then update the firmware if all of that doesn't work.
CMYKing
I have the same issue with my Graphtec 8600. It stops for less than a minute while saying it's working then starts back up. But just now it has completely frozen on me. I've been waiting for 10 minutes and I'm about to give up.
Vassago
There's sometimes an issue with Graphtecs - they overheat.. Make sure there's no dust inside, or it's a particularly hot day.
Pauly
Printrade.com.au
I've never heard of this as a problem. I've ran my 9000 over 3 years, Over night, literally 24/7 operations for months on end with 0 issues of over heating.
Vassago
Think it's down to cooling. Some versions of the board didn't allow space for cooling. I've fixed a few - the issue tended to be a lack of thermal compound. It happens to most machines - all down to how they are assembled.
Pauly
Printrade.com.au
Which board? Power or main board
Vassago
Main board primarily - power boards tend to have problems with ac ripple getting into the dc lines because the caps are old. That's why they went to thermal pads - easier to ensure there's at least some contact.
BetaCtz
Perhaps to help isolate the issue
Is it freezing while sitting dormant? or is it always during a cut job?
Do you see the problem
- after it's been sitting a long time (ie. if you print in consecutive jobs it all works for a while?)
- prints fine at the start of the day when you turn it on, but gradually gets worse?
- gets any better if you turn it off between print jobs?
Easiest would be to try a new USB cable - would negate that it's not something simple like that
(if it's during cutting only)
