Rob the rod
Graphtec FC8600-75 – After Service Reset & Cross-Cutter Calibration, Media Width Only Detects to Center Pinch Roller
I’m looking for help from anyone who has extensive experience servicing the Graphtec FC8600 series.
Machine: Graphtec FC8600-75
Background
I recently repaired the machine after replacing a damaged ribbon cable and installing a third pinch roller. After reassembly, the cross-cutter was malfunctioning.
Using Service Mode, I performed a factory/service reset and then recalibrated the cross-cutter position (using the business card method). After saving the calibration and restarting the machine, the cross-cutter now works correctly again. Test cuts are accurate, and the machine is otherwise operating normally.
Remaining Problem
The only issue left is media detection.
When I load material with three pinch rollers installed, the machine initializes only to the center pinch roller and then returns. It never continues to the third (right-most) pinch roller to measure the full media width.
If I disable the media sensors, the carriage travels all the way to the third pinch roller without any problem, and the machine is capable of cutting the full width. So the carriage, belt, encoder strip, and mechanics appear to be working correctly.
Things I’ve Already Checked
Comparison
I also own a Graphtec FC5100-100 with three pinch rollers. That machine always skips the center roller, scans all the way to the third roller, measures the full media width, and returns without any issues—even with thick stencil material.
My Questions
Any suggestions from technicians familiar with the FC8600 service procedures would be greatly appreciated. I’m trying to restore the machine so it automatically scans the full media width with all three pinch rollers, rather than using the sensor-disable workaround.
Background
Remaining Problem
- Swapped the original and replacement pinch rollers. The problem stays with the second (center) position, not with the roller itself.
- The carriage can physically travel to the third pinch roller.
- The cross-cutter has been recalibrated and is now working correctly.
- Test cuts are accurate once the media width limitation is bypassed.
- With only two pinch rollers (left and right), the machine previously scanned correctly.
Comparison
My Questions
- Is there a service-mode adjustment or calibration that controls pinch roller or media width detection?
- Is there a sensor that could cause the machine to stop at the center pinch roller during initialization?
- Is there a known procedure to recalibrate the media-width detection system after service work or a factory reset?
- Has anyone seen an FC8600 stop measuring at the center pinch roller even though the carriage is capable of traveling to the third roller?
