in Flexi you can add cropmarks the Graphtec can read for print cut. Select the graphic, it must have a contour cut created, there is a button at the top toward the right with that will light up with a small green square surrounded by four cropmarks and a dashed fence, click that and a flyout will open where you can select the type of cropmarks (Graphtec 4 Points Type 2 is the recommended), select and click the green checkmark. next send over as a print and print it. When ready to cut, select that image, click the Cut Contour button at the upper left of the screen (should become active and looks like a plotter knife symbol over a burgundy lump) - should open the Cut Contour dialog box and what shows will be the cropmarks and only the cut. Put your vinyl in the plotter, straight, press Roll 2 Current Location. After the Graphtec is ready, select your condition and navigate the knife to be inside the front right cropmark. Then in the Contour Cut dialog box click cut and it will ask you if the material is in and the knife over the cutmarks - click okay. it will begin cutting.
Try to remember that as you see your layout on screen, whatever is down is the foot and the plotter starts from the lower right of that. (Front right of the plotter as you face it, the machine considers the bottom right of your selected image on screen in Flexi.)So if you needed to rotate to print, you may need to also rotate to cut. Hope that helps.
