Grit Roller Replacement? Graphtec FC9000
milfuentes
Lately I find that the wider Grit Roller on my Graphtec FC9000 is smoother on one side and rougher on the outer side, closer to the right hand side of the control panel. Wondering how I am able to rejuvenate the grip on this piece and or where to purchase the replacement. My material has been slipping around and need to get this resolved fairly quickly. If you have any recommendations of how to fix this or where to purchase the replacement, that would be greatly appreciated!
Vassago
Been here a while..
Usually using a solvent will remove any old adhesive, etc that's stuck to the grit. Petrol works if you've nothing else.. Just use a cotton swob and dab it on.. Then peel away the gunk
  • Agree
Reactions: 1 users
d fleming
If they're toast they're toast. I got my replacement grit rollers, sheet cut knife and new blade holder direct from graphtec. Just don't lose the little c clamp when replacing the grit wheels, you'll never find that sucker once it hits the floor, lol
  • Agree
Reactions: 1 user
