Hi all! After reading some of the posts here, others and internet and Mimaki manuals, we are not be able to do a clean die cut to our polimeric vinyl sheet. The blade leaves the sheet shattered in the borders of the stickers and the cut is not clean as If you do it with a cutter knife for example. The plotter blade goes through the vynil, goes through the paper too but in a rough way.
Half Cut mode is ON and settings tested are the same as manual recommends and the cut is not perfect.
¿Has anyone had the same problems or now how to setup the parameters correctly please?
I attach the manuals I found and other posts in order to have everything on this post once we find a solution (if possible
Thank you so much in advance mates!
View attachment CG-FX Contour Cutting - How-to Guide - 5-12-05.pdf
