Hi Guys,
I've never had success with half cut - I usually end up giving up and just moving the cut line and doing a full cut through the material on the hard strip - less than ideal and ruins strips/blades, etc. BUt it drives me insane changing settings only to have the cutter totally destroy things no matter what settings I use.
In a nutshell I have sheets of printed monomeric self adhesive vinyl that I want to cut to shapes. I've tried cutting pressures from 70-140, speeds from 005 to 020, Offset 25-30, and 60deg vs 45 deg blades. I've also adjusted the half cut setup from between 0.1mm to 0.3mm half cut, pressure from 50-80g, cut distance from 5mm up to 25mm, nothing seems to work, every time the blade turns a corner in the cut it tears the material, it leaves rough edges on push out, etc, etc.
The manual is useless as it has no starting point for settings for different material - can anyone help me with at least a starting point for such material - a guide to typical half cut pressure, length of cut and length of half cut? I can't see HOW it will work as every time it turns a corner it's going to tear regardless.
Anyway enough of my ranting any suggestions would be greatly appreciated
LT.
LT.
