have a mutoh 1324 VJ . Error message reads C and M end.
EZ Ink
Will assume that the machine is reading the bags are empty, however the bags are 2/3 full. Also used backup cartridge for these two inks, again same error message.
All inks are reading low, except the two above. Any suggestions? Thanks.
Glenn Combs
  • Agree
Reactions: 1 user
Umca
It looks like the ink-end sensors are damaged. The sensor is located inside the cartridge holder, beneath the smart card contacts. If it is triggered, it may erase the value on the smart card.
You can check the sensors functionality in the diagnostics menu.
  • Agree
Reactions: 1 user
martinb
Se asume que la máquina detecta que las bolsas están vacías, pero están llenas hasta dos tercios. También se usó un cartucho de repuesto para estas dos tintas; nuevamente, el mismo mensaje de error.
Todas las tintas tienen baja lectura, excepto las dos anteriores. ¿Alguna sugerencia? Gracias.
Glenn Combs
Amigo yo tengo tu solución
EZ Ink
Did a self diagnostics on the Self Diagnotics mode. Inspection Menu -Sensor Menu, scrolled to the Ink End no. 14. Displayed indicted "InkEnd' and not CMYK as the guide reference it should display. Also hit entered, for any other displays, and sent me back to sensor menu. So to the reference will need to replaced catridge holder assembly.
question I have did I trouble shoot the above procedure correctly? Anything else I should try? Is the beginning of any other issues down the road I wll have. Already place maintenace and print head. Thanks.
