Have a Mutoh 1324 VJ, Potential Maintenance Station issue
EZ Ink
Been working with AI on trouble shooting an above issue, carriage will not release from station. Before I replace the station, it requested I check fuses 1, 2, and 3 on the main board.
I have check the board multiply time and cannot for them, They use SMD surface mount, fast acting micro fuses. However the imprint is so small I cannot read any of the imprint, as well ad fine them.
Have attached three of pictures showing the main board, would appreciate anyone that can locate them and place and arrow, to show there location. Thanks.
Glenn Combs
EZ Ink Promotions
dtfonestop
Attila's pointer is a good one, on a lot of these boards the fuses sit near the heatsink. Reading the markings on those little SMD parts is rough even with a loupe, so I wouldn't count on the print. Usually the part itself isn't labeled, it's the silkscreen next to it that says F1, F2, F3, and the fuses are small two-pad parts, usually black or tan. With the printer unplugged, put a multimeter on continuity or the lowest ohms setting and touch both ends of each suspect part. A good fuse reads close to zero and an open one reads nothing, which is a lot quicker than trying to spot them in photos, and if they all read fine you've ruled the fuses out in a few minutes.
Before buying a station I'd also rule out the mechanical side, because a carriage that won't leave the caps is very often just stuck rather than electrical. Dried ink and gunk on the cap slider, the wiper and the little rails the station rides on can be enough to keep the caps latched up, and a careful clean with lint-free swabs and cleaning solution sometimes frees it. It's also worth reseating the station motor and sensor connectors, then watching the station when you power up. If you hear the motor try and the caps don't drop, that points to a stuck mechanism or a worn drive gear. If it's completely silent, it leans more toward power, a connector or the sensor.
If the station moves freely and the carriage still won't release on start-up, that's when the sensor or the board side becomes more likely, and a new station alone might not fix it. Just go easy if you move the carriage by hand while the heads are sitting on the caps, so you don't drag the head face across the wiper.
