Have a VJ 1324 X with error code (KM) S/C Col. Err perform ink charge
EZ Ink
Discovered the problem when printing, image was fine, then turn a different color.
Appears yellow not working, Did a nozzle and cleaning. . Received the above error code. Yellow was not printing (I have a bulk system) I Notice a lot of yellow ink on the yellow cartridge slot. Did not see a leak though.
Next Attempted ink charge both normal and little. Received an error light with no code. Check manual or error messages and did not find the one I have.
Reset Power with not change. Still received the same code. Any suggestions I could try. Thank.
Glenn
EZ Ink Promotions
EZ Ink
Glenn
EZ Ink Promotions
Disregard. Clean my port and found the drip coming from my bulk yellow cartridge. Applied some solvent in the small ink cartridge nozzle and placed it back into the port. Then printer started an automatic refill process (never seen that before). The other error was a mistake I made in putting the wrong cartridge in the wrong port. The above process took 2 hours to figure out. Thought I would share that with you folks. Thanks.
Reactions: 1 users
