Having problem cutting script text
shuv76
Hello,,-----I have corel x3 and I am cutting script fonts and I tried welding it first before cutting but when it cuts the letter, it cuts into the letter that it is attached to in the script. I am missing something. I even tried converting it to curves and then welding but no luck. Any help would be greatly appreciated....Paul
TammieH
Not sure what steps you went through, did you convert the text to curves first? It should not matter either way.
I just did a test in Corel X3, ( I don't use Corel, only when I have to convert a file.)
But it seems to work both ways, for me
Convert text to curve first then weld
And I just welded text.
Looks fine no overlap
shuv76
Ok it did work! I must have not converted it to curvews first...Thank you very much,,,Paul
