Having Trouble Importing Large Cut File into OptiScout (Colex)
bpp
I’m trying to import a cut file into OptiScout to cut on my Colex. The file shows up on screen, but it never fully loads — the mouse just keeps spinning and it doesn’t finish bringing it in.
The file contains around 900 small decals. If I break it into smaller files of 100–200 decals, it eventually loads (though it takes a few minutes).
Has anyone run into this issue or found a workaround for large batch imports? Any suggestions would be much appreciated.
bpp
There is no artwork, just a lot of nodes maybe. I left it spinning overnight and it eventually opened (after I already reprinted it in smaller batches :cool:)
JBurton
Signtologist
Are these squares, circles, or some wonky custom shape?
I'd think you could export them in 9 batches, using the same marks, and just run each batch individually, but if your rip is placing your marks, this would be a complicated nightmare.
I wonder how firesprint handles this, I'm sure they handle such orders, and since they aren't fans of just dealing with halfbaked options, surely they've found a way to automate this.
If it were just a bunch of squares, I'd say you could replace the 4 sides with 4 cuts, that cut across the whole sheet. So for like a 4x4 grid, you'd need 10 straight lines to cut them out, vs 16 lines making up individual squares.
This reminds me of that one time I tried to generate a vector file that was 1200 dpi of black squares with white voids, and quickly realized my beefy setup was getting crippled by the bajillion nodes in the file.
JBurton
Signtologist
Vector files have no dpi.
I misspoke. I made a checkerboard, using vector squares, to make a file that was 1200dpi at scale. I only got about 2/3 of the square filled in before it just kept crashing. For whatever reason I didn't use step and repeat.
After I wrote this I went and found the art, exported it, and tried to print it. That's when I realized my copy of onyx only goes to 600dpi, a realization I must have had previously and just forgotten.
myront
Dammit, make it faster!!
Why not just leave it as vector? Why the need for 1200dpi or 600, for that matter?
JBurton
Signtologist
That was the intent.
What I really wanted was to see what a 1200dpi checkerboard would look like, wondering if it would look like 50% black, or like a halftone grey, or like a high resolution checkerboard.
