Help! Breaking down curved car panels to design flat and seamless art…
BrentNaquin
I was commissioned to design a vehicle wrap with artwork that seamlessly aligns across all panels (like the image below). While I can achieve this using my current 2D sign element templates—which are highly accurate—I want to take my designs to the next level, ensuring the graphics flow perfectly from bumper to trunk without visible breaks.
I am looking for professional resources to help with this, such as tools or software for 3D mapping, panel flattening, or advanced vehicle templates that allow me to design on a single continuous layout. Any recommendations on 3D design software, template sources, or best practices for achieving precise alignment in printing and installation would be greatly appreciated. Thank you. MEb4aa75cb6d5716fcc947ea64c766b636.jpeg
tulsagraphics
Blender, Fusion 360, SolidWorks, Rhino, and others can all do this. Basically you're taking a 3d model -- adding seams -- then unfolding / flattening the polygons (typically with the help of a tool or extension designed for those programs). Search online for "how to unfold / flatten 3D models [in your preferred 3D modeling software]"
^ This method can help you get all your panels flattened, but the real hurdle is that you're working in an exploded 2D view where most of the panel edges aren't touching each other, so you'll have a LOT of fiddling / eyeballing to do when placing various graphical elements. Another thing is locating an accurate 3D model, properly scaled, that matches the exact car you're working on. Obviously you're not going to buy a professional 3D scanner for a one-off job -- maybe you'll get lucky searching 3D vehicle template databases?
That being said, I wouldn't dive into 3D modeling for a car wrap. You could totally get rabbit-holed on this, especially if you're not used to 3D modeling. If you see a "continuous design" vehicle wrap in person, take a closer look. Most likely extra material (bleed) was printed and the installer knew how to make adjustments to line them up or hide the imperfections. Of course, it helps when the designer doesn't overcomplicate the layout. The photo you provided is NOT a complicated design or install. There's just so much "noise" in that artwork -- it's very easy to hide the seams / misalignments.
Just my 2¢
Reactions: 1 users
damonCA21
Basically you can't unless you have a 100% accurate 3D model of the specific car. Some software can sort of guess what the panel will look like flattened, but unless it knows the specific curves then it isn't totally accurate. ( Imagine looking at a beer can straight on. The software will see a rectangle, not a cylinder )
The only real way to do it is to make your own templates from the vehicle in front of you, but as Tulsa says, most wrappers will allow a bleed on each panel part and then line them up as well as possible by eye so they transition well
Jessy_1
I am looking for professional resources to help with this, such as tools or software for 3D mapping, panel flattening, or advanced vehicle templates that allow me to design on a single continuous layout. Any recommendations on 3D design software, template sources, or best practices for achieving precise alignment in printing and installation would be greatly appreciated. Thank you. View attachment 179597
We use ProVehicle Outline. It's a subscription based software that has almost all vehicle templates at 20th scale. But it's only a 2d rendering of it. You can fiddle around when you make the panels to get everything to align. Give more bleed then you think.
