help needed with this heat (weather)
connie black
Hi,
We are using scotchlite vinyl red...cut it, weed it, cover with carrier sheet...but then when we go to adhere it to the aluminum license plate - it doesn't release the back carrier... have put into the freezer and tried to go it cold..a bit better. Anyone have any tricks to get the back carrier which is attached to the roll of vinyl to release easier.
Thanks for your time and input!!!!
unclebun
Peel the paper off rather than peeling the lettering off. It's possible you cut too hard into the paper. That will also make it stick and be hard to get loose.
cornholio
Cut too deep, or using the wrong transfer tape. There are three differently tacking transfer tapes available from 3M. (Other vendors will have it as well)
aidonscott
Sometimes the vinyl just doesn’t want to let go of the backing, especially with certain brands. Maybe try a lighter pressure on the cut so it doesn’t bite into the carrier too much.
