Help needed
mfatty500
I'm using my old Graphgec CE-5000 series cutter, I'm trying to use Cut-Master 5 with my Corel Draw 2025, but it's not supported by Graphtec, what do I do? Any suggestions are welcomed!
Smoke_Jaguar
Best bet is check with the software vendor. The Graphtec stuff is pretty basic in its command sets (HPGL), so should be able to run it with most cutting software.
  • Agree
Reactions: 1 user
LizKeenan
Have you tried putting directly in whatever plug in folder it goes and seeing if it runs? Otherwise try illustrator 2025
