Im having a tough time pricing this one. Most menu boards I did was on either foamboard or coroplast. just simple design.
Basically, what Im thinking of material to be use here is mostly plexiglass, magnum magnetic rubbersteel and wood. Plus printed graphics on Photopaper.
There would be 8 panels (plexi ) mounted on 15 ft of plexiglass but I will divide them into 5 and 3 panels because they will be on different sides.
The 15 ft will serve as substrate to hold the panels so I might be needing at least 2 48" x 96" sheet of 1/4 plexiglass and 2 sheet of 1/8 plexi for the panels and other trimmings.
I hope you can see the image and If you will be doing this menuboard how are you going to do this what material to be use and how much will you charge the client for doing this one.
Note that this is to be hang thats is why I thought of plexiglass cuz its lightweight. No foamboard this time.
The size will be
- panels will be 8 1/8 20" x 25" plexi
- 1 1/4 2' x 9' plexi
- 1 1/4 2' x 6' plexi
- 22 1.25" x 25" x 1/4" wood trim
I hope you understand what I want to accomplish. Thanks alot for any help
The size will be
