Cut Carriage Cable
Stop messing with the encoder strip... it has nothing to with looking for pinch wheels.
You have a micro break in your cut carriage cable. This is a common issue.
The cut carriage cable carries three signals from the cut carriage to the mainboard...
- Cropmark Sensor
- Pinch wheel Sensor
- Contour Knife Downforce Data
This cable will need to be replaced along with the two plastic guides in the track (approx $50 parts). Quick replacement.
See parts list below.
| Item Number | Item Description | List Price | Qty on Hand |
| 22305102 | GUIDE,CUT CARRIAGE CABLE SP-300 YOU NEED TWO OF THESE | $6.95 | 88 |
| 23475207 | CABLE CARD 15P 1900 LONG SP-300 YOU NEED ONE OF THESE | $26.15 | 117 |
These parts are available from your preferred Roland dealer (most stock these common parts).
This is an easy repair, but you should consult your dealer/tech for advise.
Note: While the cables are out, it would be a good time to clean out the track real good with isopropyl alcohol then use some Dry Teflon fluid (liquid application, quick dry) to coat the surfaces inside the track. This will help to prevent the cable/guides from kinking in the track.
Merry Christmas!
~E
