Help w/HP 360 Dbl-sided printing
Mike Brice
Is it possible to print different images on a double sided banner with the HP 360. I've done same image on both but we have a job now that requires separate images. Thanks in advance for the input.
myront
CorelDRAW is best
Yes, we do it all the time. Drop two seperate files into the RIP hot folder. Print side A flip and print side b. Side a has a cut & fold line, as well as, dots for grommet placement. Simply omit all that stuff for side B but include the blank perimeter of the banner if not a full edge print. Mark your leading edge placement so when you flip you know where to begin again. You get the gist of it. I don't know the exact procedure because I'm not the print tech.
