Help with a Roland XC-540.
adielm86
Hi everyone, I’m looking for some help with a Roland XC-540.
I recently got two Roland printers for "free"—one XC-540 and another XC-540MT. Both machines have been sitting unused for over two years. Right now I’m focusing on getting the XC-540 back up and running.
I’m not a certified printer technician, but I do have a solid background in electronics and some experience with other printers (mainly Epson). I’ve been doing my homework: I got the service manual, studied it, and went through the machine thoroughly. So far I’ve disassembled parts of it, flushed the ink system, replaced the dampers and cap tops, cleaned the pumps (one had a broken internal hose), soaked the printheads, and checked fuses, among other things.
After reinstalling the printheads, the nozzle check came out very poor. I also noticed that the cap tops are not properly aligned with the printheads. Sometimes they don’t seal correctly and even end up hitting the metal frame under the printhead instead of sealing against it.
I tried to figure out how to adjust or realign the cap tops, but I haven’t found a clear solution yet.
I understand I may need to replace the printheads, but before doing that I’d like to resolve the capping issue. Has anyone dealt with misaligned cap tops on this model? Any suggestions on how to properly align or adjust the cap station would be greatly appreciated.
Thanks in advance.
cornholio
The captops need to bei installed the right way around. 180° wrong wont work. Remove the plastic part, that hangs beside the tubing. Use genuine Roland/Epson parts.
If you have a left/right displacement, adjust the whole capping station with the four screws fixing it to the printer.
I just fixed a printer, that sat idle for a prolonged time. The nozzle plates had corrosion, so no chance of recovering. Just replacement helps.
Reactions: 2 users
damonCA21
If they have been sitting for over two years they will both need all the print heads replacing. Soaking them isn't going to bring them back enough
Six printhead will be expensive. Soak overnight, run medium clean. Do that for several days, you might get them back if lucky.
make sure you are clamping the captop lines with a non-toothed tool. the small black office clips will work on those rubber lines, fold the line and place the clip. Make sure cleaning solution does not drain in cap, POWER OFF printer when soaking. Use pipe tool to lower and raise heads.
damonCA21
After two years? :eek:
I have had a VP that sat in a closet unplugged for two years. I was able to get all the heads freed up by soaking them for two days returning, running cleaning cycles, re-soaking. Over two week period of time. I got all the heads back. This has happened two times on that exact same printer Over the last 8 years. Guess what. I am going to see that customer again today. What do you think they have done over the last year………
adielm86
Hi everyone, thanks for your ideas. I’m trying to do the best I can, and your ideas help me a lot.
cornholio, I checked the installation of the captops, and they are in the correct position. I verified this according to the service manual. I tried to align the new captops with the printheads, but I was unsuccessful. I had to go back to the ones that came with the machine because they seal better than the new ones.
I’m going to try to get new ones. Maybe the problem is that the ones I bought are not good quality. Should I also replace the frame that holds them?
Regarding the printheads, I’ve been cleaning them for about a month using a machine that heats and regulates the fluid flow through them. Out of the 12 printheads, I was able to unclog 6 and installed them. The yellow and black printheads don’t print anything, so I think they may be electrically dead because I checked the fuses, and they are OK. I also swapped the flex with the ones from the LC/LM group, which are working and printing, but the yellow and black printheads still don’t print anything.
The other printheads (C/M) are showing incomplete patterns when I run the printhead checks.
What cleaning fluid would you recommend I use? I’m currently using a Mexican-made cleaning solution that contains butoxyethyl acetate.
Again, thanks for your ideas.
adielm86
What cleaning solution do you use to soak the heads?
