Help with banner pricing.
parkedcar
I usually charge around $7.50/sq.ft for banners, but i'm not sure where i should be on a large quantity.
A really good customer of mine that i wholesale to, just passed along an opportunity on bout 50 banners. They will be 2'x3' and they will be printed and finished.
Based on the customers "idea" it looks like i'll have about 1 hr invested in design at $75/hr but i'm not 100% where i should be for the banners themselves. I've never done more than 3 or 4 at a time. So what would you charge?
Thanks!
kustomkoncepts
they are 6 sq ft and I agree with the above.
I get around $10 Sq Ft Retail and bigger banners or quantity it gets around $4 sq ft
t
osmasterflex
Do any of you know the ink usage price/square foot? Roland says its .16/ square foot, but your program (GXSignCo) says its .34 cents for Eco-Sol...
ChiknNutz
Ink usage is a bit hard to figure out accurately, but what I use is ink cost per Liter / 1000. You can adjust those figures in GraphixCALC based on what you pay for ink. If you buy in cartridges, just need to calculate what that works out to per Liter. However, ink coverage and resolution also play a part in all of it too. Here is another resource to check out Nu-Flex and some of their estimated ink prices PSF when using Triangle Bulk Ink.
ESTIMATED PRINTING COSTS
• $0.15 per SQFT at 720x720 dpi
• $0.12 per SQFT at 360x720 dpi
• $0.07 per SQFT at 360x360 dpi
kustomkoncepts
I actually have a digital gram scale and measured all inks before a big trailer wrap and came to the conclusion that you are closer to the .34 Sq Ft this was full saturation blues and greens. always just figure you are at .50 sq ft ink and it will work out.
parkedcar
Thanks guys for the responses!
I was told they have a $2000 budget, so that should be good for around 50-60 banners plus design time.
I'm also not set-up for printing in house yet, so if i get the job, they'll be subbed out anyway. So i guess i'd be looking at about a 100% mark-up plus my design time.
ndemond
When speaking to a potential client it is one of the last things I ask them before figuring out a quote You should be able to think it through rather quickly, if you can keep within their budget before gving them a firm price. You may have tried to squeeze that extra 10.00 a banner out of them and then you would have been over their budget and they may have gone some place else.
Nancy
kustomkoncepts
Once you are set up for doing your inhouse printing you would make a killing at $20 ea You are going to doing awsome at $50-$60ea
it will only cost about $150 Material and ink to print them.
rcook99
What are you printing with and what inks are you using?
It seems that just the ink alone would cost you $150 plus the banner material.
ChiknNutz
It's only 300 SF of materials here....I figured I'd have about $150 in to them too...pure material cost anyway...excluding labor.
kustomkoncepts
These are only 300 Sq Ft Total for 50 2x3's
I din't always like SQ FT because I know my Pearl 14 oz banner material is a 40 YD roll and 54" wide but it is only $120 for the roll.
so $1 Linier foot
for all 50 it will take 100 Ft....................$100
Ink Eco Sol Max $.30 on the high side sq ft...........$90
so I was a little off but $190 Max
and depending on the colors ink is hard to tell that is why I use .30 but most of the time it will be around .16-.22 sq ft INK
rcook99
GXsingCO and kustomkoncepts I appreciate the input! I was looking at the .50 psf in your post(9) and then added the banner and came up with $250. No biggie:thumb::thankyou:
kustomkoncepts
sorry for the confusion From #9 .50 is the safe High Number..
When I did a 48' trailer wrap I used a digital scale and weighted all the cartiages and wrote down weight then when it was done re weighted and found out what ink it used. all colors get used differently depending on what colors are printing so Real time ink prices are almost impossible. but I came up with .34 sq ft and for the most part I usually don't think about ink but in the back of my mind I think about .50 sq ft when printing any thing this takes in to account the
Ink
Transfer Paper
Kraft Paper
Paper towels
Misl Supplies
and is a good round number to just think about but with so many variables I don't worry about it much I usually know My Cost Per Linier foot with different materials and go by that.
